This board uses passive cooling for the mobo chipset, as shown here - http://www.bit-tech.net/hardware/2005/12/01/abit_an8_sli/2.html
Mine tends to get above 50 degrees when under load, and even though i've heard they can go pretty high without damage, i'd rather have it a bit cooler.
The exhaust area is above the CPU fan, and my arctic freezer pro doesnt really blow any air out of the Q-OTES exhaust.
When i was messing about with my system and it was out of the case, having a 120mm fan blowing over the exhaust cooled temps by about 5 degrees. Now my problem is how i'm going to do that when everything is in the case.
Having a fan inside blowing air out the exhaust is the most obvious, but it would need to be a pathetic 40mm fan for it to fit in - that's if i can find a way of suspending it under the PSU.
My other option is to mount a fan outside the case, 'sucking' air out if you will. Unfortunately, the air a fan blows does not equal the amount it sucks in perpendicular to the fan, so this may not help much.
The only other option i can think of is to have a fan blowing INTO the case via the q-OTES exhaust, and hope that the cpu fan will redirect the hot air out of the case exhaust.
If i were to do this, i'd then have to decide whether to use a 120mm fan, or 2 40mm fans side by side, which covers the exhaust perfectly.
Any ideas/tips? Especially on how to have fans inside the case where you're not really meant to have fans =/ (no superglue please!)
