- 28 Jul 2003
- South Wales
Seems reviews of the octavia return around 44mpg, I was hoping for closer to 55. I should get this on a 75% motorway journey to work.
Buy a £700 306 Dturbo, still a respectable and reliable car and put the savings towards a nice weekend toy!
[TW]Fox;21720874 said:You are buying 10 year old tech from before everyone got good fuel consumption tests. 55mpg as an average is a big ask from ANY of these cars.
I'm going to throw in a Rover 75 with the 2.0CDTi, they represent some fairly decent VFM at the moment and reports are 45+mpg averages. The 1.9 PD stuff all seems to have a serious premium on it at the moment.
If you get a 110 TDI (non-PD, pre 2001) you can run on veg oil mix if you really want to cut costs.
skoda octavia,
keep the ST tucked away for the weekends and scour the free ads or local taxi companies for a moon mileage ex taxi octavia for a grand.
one of the big operators up here just parted out 50+ 05/55 plate octavia estates for £1200 a pop or thereabouts, christ mate of mine bought a high mileage A5 shape octavia for £1400 a couple of months back on an 06 plate.
or if you want something a bit more in your budget i'd suggest a superb,
very nice place to spend a commute and you could pick up a 07/57 plate with high miles in budget or an older one with less miles if your put off by the magic 100k number,
the 1.9 tdi lumps WILL run forver if their looked after, personally i've had 300k out of one but theres ones known to me with over 1/2 million miles on them
or if you dont fancy a superb what about this?
http://www4.autotrader.co.uk/classi.../postcode/g326en/radius/1501/page/1?logcode=p
granted its likely to have 150k or more miles on it, but its a toyota it will run forever![]()
