Need a cooler for this system please
23 Oct 2004
Ipswich UK
This is the spec I am about to purchase but want to try and find a cooler that will fit and wont cause problems with the ram. If you can see a hardware conflict or anything id appreciate your help thanks.
Corsair 600T Graphite Series Black Mid Tower Gaming Case, w/o PSU
Asus P8Z68-V PRO, Intel Z68, S 1155, PCI-E 2.0 (x16), DDR3 2200(OC), SATA 6Gb/s, RAID, ATX, HDMI
Intel Core i7 2600K Unlocked, S1155, Sandy Bridge, Quad Core, 3.4GHz, GPU 850Mhz 8MB Cache, 95W OEM
850W Corsair Enthusiast 850TXV2UK TX V2 Series, 85% Eff', SLi, EPS 12V, 80 Plus Bronze, 140mm Fan
1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9ms,
60GB OCZ Technology Vertex 2E, 2.5" Sandforce SSD, MLC-Flash, Read 285MB/s, Write 275MB/s
1536MB MSI GTX 580 Twin FrozR II/OC, 40nm, 4096MHz GDDR5, GPU 800MHz, Shader 1544MHz, 512 Cores
8GB (2x4GB) Corsair Vengeance Blue DDR3 PC3-12800(1600), Non-ECC Unbuffered, CAS 9-9-9-24, XMP, 1.5V
Microsoft Windows 7 Home Premium 64 Bit SP1, Operating System, Single, - OEM
tbh just want the best reasonable priced cooler for the system I have built thanks !!!!
