- 29 Jun 2013
I have a three year old Asus P6T Deluxe V2 motherboard with an i7 920. It is warmer than it should be. (Idle 50C, but 82C when running Prime95.) Only slightly overclocked, BCLK=166 instead of 133, and I've just reduced it to 150 to keep the temperature down, now 47C when idle).
The cooler is a Thermalright Ultra 120 1366RT eXtreme CPU cooler with 120mm fan.
The fan speed doesn't change, it stays at 1500 - 1562 rpm. I understand that this fan is not capable of changing speed, although it does report its speed correctly to the motherboard.
Is there any way to change the fan on this cooler so that it changes speed? Would a different fan attach to the cooler? Would this help? Thanks.
