I got asked this last year:
There are three light switches on the outside of a closed room, each light switch corresponds to a different light bulb inside the room. You are only allowed to look/go inside the room once. How can you tell which light switch corresponds to each bulb?
Bingo, though my first response was to put a servo + timer mechanism on one of the switchesSwitch the first switch on.
Wait 10 mins
Switch the first switch off
Switch the second switch on
Go into room
Hot bulb - Switch 1
Lit bulb - Switch 2
Cold bulb - Switch 3
Am I missing something with the moose question?
Can you explain the female mind in no less that 300 words.
The answer is always No.
Explain inflation in one sentence.
What happens if the Unstoppable Force meets the Immovable Object ?
