- 1 Jan 2003
- Derbyshire
I was wondering if anyone has a spare Intel socket 1150 cpu (see list below), and would be kind enough to lend it me, so I can update a motherboard. I'll cover the postage
You can check my trust rating, Ive been here for quite a few years.
I've just purchased a motherboard from the members market here, but it turns out the bios on the motherboard isnt current enough to run either of the socket 1150 cpu's I have here (i7-4790k & G3258). And I dont have a compatible (old enough) cpu, to update the bios. The motherboard just doesnt post, so I cant even access bios
The seller has already sold his cpu that ran in the motherboard, so he cant do anything either.
After some googling others have suffered the same and its just a case of updating the bios, and jobs a good un
But I need a cpu that is compatible with the early bios revision.
From the MSI's website any of these should do:
Core i7 Haswell i7-4771
Core i7 Haswell i7-4770T
Core i7 Haswell i7-4770S
Core i7 Haswell i7-4770K
Core i7 Haswell i7-4765T
Core i5 Haswell i5-4670T
Core i5 Haswell i5-4670S
Core i5 Haswell i5-4670K
Core i5 Haswell i5-4570T
Core i5 Haswell i5-4570S
Core i5 Haswell i5-4440S
Core i5 Haswell i5-4430S
Core i3 Haswell i3-4340
Core i3 Haswell i3-4330T
Core i3 Haswell i3-4130T
Pentium Haswell G3430
Pentium Haswell G3420T
Pentium Haswell G3220T
Celeron Haswell G1830
Celeron Haswell G1820T
Xeon Haswell E3-1285
Xeon Haswell E3-1280
Xeon Haswell E3-1275
Xeon Haswell E3-1265L
Xeon Haswell E3-1245
Xeon Haswell E3-1230L
Xeon Haswell E3-1225
Xeon Haswell E3-1220L
I'd really appreciate it if anyone could help out.
Thanks
Mick
You can check my trust rating, Ive been here for quite a few years.I've just purchased a motherboard from the members market here, but it turns out the bios on the motherboard isnt current enough to run either of the socket 1150 cpu's I have here (i7-4790k & G3258). And I dont have a compatible (old enough) cpu, to update the bios. The motherboard just doesnt post, so I cant even access bios
The seller has already sold his cpu that ran in the motherboard, so he cant do anything either.After some googling others have suffered the same and its just a case of updating the bios, and jobs a good un
But I need a cpu that is compatible with the early bios revision.From the MSI's website any of these should do:
Thanks
Mick
