Need a little help please!
3 Jan 2012
I need a bit of help 'diagnosing' and getting my PC back up and running. I'm practically a newbie at building custom computers, the PC I have was built by an online retailer and delivered to me ready to go, this was my set-up:
  • ANTEC 900 Case
  • Gigabyte GA-EX58-UD3R (Intel X58)
  • OCZ 700W StealthXStream
  • Intel Core i7 950 (4 x 3.06GHz) 8 MB 4.8GT/s
  • Corsair Hydro Series H50
  • Corsair 6GB (3x2GB) XMS3 1333MHz DDR3
  • ATI Radeon HD 5870 (OC'd via ATI Overdrive by the retailer, at my request.)
  • Microsoft Windows 7 Home Premium 64
  • Samsung16x DVD-ROM Black
It worked like a dream and after a month or so I found the courage to take all the peripherals and the PSU out to re-arrange the cables so the insides look more organized. I had no problems after I'd done this and my PC worked beautifully for about a year. A few months ago however the PSU gave of an awful electronic burning smell and cut out with a snap and a puff of smoke before I realized what it was. Out of frustration and curiosity I opened up the PSU to find this:
A burnt out inductor/(transformer?). I personally have no clue as to what would have caused this to happen, but since then my PC had been sat on top of my wardrobe until last week when I ordered a Corsair TX650 V2. Despite this model being 50W less than the OCZ, a couple of online PSU 'calculators' informed me that this model is more than powerful enough to run my hardware (and it is listed on the ATI website as specifically compatible with the 5870).
When the TX650 arrived, I connected everything up and booted to Windows with seemingly no problems - The H50 was working, all the fans were working, the graphics card seemed to have no issues (though I didn't test it under load) and my second hard drive (which I store music on) was identified and still had all the data on it. I shut it down to come back later.
Then later arrived; I booted up the PC again without no issues, I browsed some inter-webs, connected my MP3 players to transfer some files (the same one I've had for three years), then 5 minutes later my screen went black and the fan on the 5870 sped up to what sounded like max RPM, to which my knee-jerk reaction was flicking the I/O switch on the PSU.
After 5 minutes I flicked it back on, powered up the PC and once again it booted to windows without problems; the 5870 fan running as it normally does when it's idle. This time however, a couple of minutes after windows had loaded, my PC cut out completely, then flickered for a split second.
After this it would not boot at all. I disconnected the TX650 and tested it via the 'paper clip' test, all that happened was a flicker of the LEDs on the single fan I'd connected.
I am literally at a loss to as to what's up with my PC right now...
If there was a short or perhaps the HDDs were damaged - surely the thing wouldn't boot at all?
If the graphics card was shot, it wouldn't output to a display that was connected to it?
Have I just been unlucky to receive a dud PSU?
I'm going to try and return this PSU and get a replacement - the trouble is taking the risk of connecting one up again if some other unseen problem is going to cause it to blow... here's hoping it was just the PSU. :(
Any help would be appreciated, whether it's some guidance on testing, or some information as to why any of the weird behaviors above may have occurred.
Firstly, can you get the original PSU replaced? Hopefully its in warranty. You are corrent, 650W is plenty for that system (PSU calculators normally overestimate, but you bought a good brand so that's no problem).
Just to clarify, trying the paper clip test didn't even run a single fan!? Sounds like you've got another dead PSU :(
The warranty on the OCZ was void the moment I opened it up, I even went on their forum and posted the picture, asking if it would have caused any damage to other parts of my PC. Evidently it didn't or I doubt it would have booted as smoothly as it did.
