- 5 Aug 2003
- Essex
Crazy Fool said:i'm starting to think balls! spend £200
Logitech Z-5500 ?![]()
Go for it, or spend a bit less and get the Z680s, pretty much the same thing
Sirrel Squirrel said:Go for it, or spend a bit less and get the Z680s, pretty much the same thing
Crazy Fool said:just trying to find out if my SN41G2 is 5.1 !!!!!!!!!! please let be as i feel like blowing some cash i don't have then feeling guilty later![]()
Sirrel Squirrel said:I'm pretty sure shuttles are 5.1 through the optical out on the back or using the analog outputs, you could invest in a Hi-Tec Xplosion sound card http://www.overclockers.co.uk/acatalog/HiTeC_Soundcards.html and get DTS and Dolby Live encoding so your games become 5.1 through the optical output but then you could just use the analog ports on your shuttle for analog 5.1 in games and it'll still sound good
ajgoodfellow said:All of the analogue leads definitely will
They don't always include the optical or digital leads
so i want a good sound system to match the sound card. He been sending a few pics and it looks good.
