need a low resource os
22 Sep 2006
London
i have a small dell latitude l400, pentium3, 500mhz! 256 ram!
Currently runs XP and has done for some time, but its just slow (no supprise)
Im looking to try a linux (or another?) O/S which may run better on it. only want it for browsing the internet (firefox pref) I also have a dlink dwl-650 wireless card which is needed. however i dont know if that will work with it?
cheers for any help/advice/etc
I've noticed that Xubuntu doesnt seem a great deal faster then Ubuntu with Gnome, i think it maybe becasue my pc is powerfull enough perhaps
Crunchbang ought to be light enough, as it does away with a lot of the visuals used by Ubuntu. If not, then try TinyMe or Puppy.
If you'r comfortable with a command prompt - then either Arch (either a core or an FTP install) or Debian (net install). If not, then go for Knoppix (debian based), Puppy (dunno what this is based on) or DSL (Damn Small Linux - might be Deb based as well - not used it in a long time).
Knoppix is basically a mini-fully fledged linux which comes with a bunch of apps. To install, get the normal Knoppix live CD and there's a menu entry to install to your HDD.
Puppy has slightly less bits, but will generally do everything that you want (internet, email, etc).
DSL is a mini-distro which his optimised for both size and [lack of] resources: it comes as a 50 MB ISO and can be installed to the HDD if wanted.
Your best bet is to try them all out, as they all come on live cds.
Personally, I would recommend Arch or Debian - as these are by far the most powerful and flexible of the five that I have suggested.
The Debian net install allows you full choice whilst installed, however, my personal preference goes to Arch as I find that Debian "holds your hand" just a bit too much, even once it's installed.
The down side of Arch is it does not come with a window manager by default, so if you're not comfortable with the shell, you might not like this one very much.
great post, thanks!
i will give "puppy" a go, not sure a console based op will suit, ill get annoyed and means having to learn commands!
will report bk
