- 26 Aug 2004
I want to spend around £20 max and I'm thinking about getting this:
http://www.arctic-cooling.com/cpu2.php?idx=79
At 4 ghz, my temps are:
Idle ~50 C
Load ~68+
This is with the stock intel HSF and at full rpm, which is noisy.![Frown :( :(](/styles/default/xenforo/vbSmilies/Normal/frown.gif)
Is the one I mentioned above any good? What temps do you think I will get? I just want a new cooler that is easy to install with the four pins (775 socket) and has better cooling...
I'm also wondering if anyone has the dimensions as I'd like to know if it would fit with my ASUS P5WD2 PREMIUM and Thermaltake Soprano Case.
Thanks
Idle ~50 C
Load ~68+
Thanks
