Hello everyone,
Well I'm quite in bad situation right now, cause I can't find any good cases that would suit my needs I'm building AMD Threadripper 1950x with best X399 motherboard ASUS ROG Zenith Extreme, and the board is E-ATX size 12 inch x 10.9 inch ( 30.5 cm x 27.7 cm ). All cases that I like, has a sleek design, not huge, not fancy etc.. and has front panel USB Type C,and no "fancy" vertical GPU mount, will not fit my ASUS ROG Zenith Extreme, cause it just wide. I really like Lian Li PC-O11WGX, But my motherboard it just to wide to fit it, or the new Be Quit Dark Base 700. The only case that I found would suit me Cooler Master Cosmos C700P, but the case it self to me is quite bulky, and doesn't look that sleek. I will build a custom loop watercooling for my build, But most cases that fit E-ATX Mobo already has good support for radiators and reservoir.
MY budget is around 300£ for the case itself, but if the case is really good, or don't have any other option left would go extra on the budget.
Thank you guys for any recommendation.
