Need a NON tacky case :)
I'd probably get the XL myself am sure the cooling can be improved by adding a fan to the 5.25 bay.
The Fractal cases are easily the best in that price range.
well theres the lancool k62 and Coolermaster CM-690 II Advanced Dominator neither to be sniffed at in this 70-90 range.
The problem with the fractal Xl is questionable cooling performance I think you need to add a fan to the 525 bay.
Lancool PC-K62. Looks awesome and has all the features you need. Isn't as big as the XL, but the interior layout will fit your system easily with some cable management.
I've just about finished building in the Fractal XL.. i'd say its great yes however it is massive.. but if the R3 is of the same quality then can't go too far wrong!
