need a pc build £1500 budget
19 Apr 2020
hello i need a pc build i have a 144hz monitor good keyboard mouse so just need the pc i am looking to play first person shooter like cod and valarant nice and smooth .£1500 budget but can wiggle if need to some help would be grate thanks
Price performance & the fact that Intel doesn't offer much in the way of upgrading to a Newer generation CPU at a later date. AMD does offer that for Zen 3 (Due out later this year) with Current AM4 Motherboards. Intels current Socket 1151 Motherboards wont be supporting Intels 'comet lake' CPU's, a new motherboard would be required.
ok thanks for that could i swap out the case for the
ECLIPSE P400 AIR MIDI TOWER DRGB CASE - BLACK it looks the same just with fans on the front
Yep. It's the same case with Phanteks own RGB Fans, No idea if said fans are any good, I doubt that they will be PWM for that price though (PWM means you can control the fan RPM speed via the motherboard or by a PWM Fan controller) If they are fixed speed you could buy some adaptors to lower their RPM speed or '7volt mod' them.
