Hi,
I've had a problem with my boiler for quite a while but not had the money to fix it.
Initially, I noticed the hot water wasn't coming out very hot when I turned it on full blast. I used to turn my shower on (via bath taps) hot water on full, and then a bit of cold to cool it down. I then noticed the temperature dropping so I just had the hot water tap on.
Then the issue developed further a week or so later, the water came out less and less hot, so I had to turn the hot water tap down to reduce the speed of the flow. This made it a bit warmer.
Again, it got worse a week or two later, it would then output hot water for 10-20 seconds, and then go cold, and repeat.
Now the boiler wont work at all for hot water or central heating. The front boiler panel was showing error H 3.
With a new job and more urgency I decided to get a plumber out. He messed me around countless times by not showing or not calling. Looking in the manual the faulty part was a DHW Thermistor. I replaced this but the fault is still there. I disconnected the boiler from the mains for a while but this made no difference. The boiler also doesn't respond to the Reset button. It just stays flashing H 3
The manual suggests the fault could be the main PCB. Research shows these are eye watering expensive!
A quick Google shows there is a decent person that refurbs PCB's : http://www.ebay.co.uk/itm/IDEAL-ICO..._Air&hash=item53ebc1725b&_uhb=1#ht_1465wt_952
Am I going down the correct route in replacing this? Do my symptoms point towards a faulty PCB?
My boiler is an Ideal HE35
Any advice from plumbers would be welcome.
Thanks.
Thanks.
working whilst reading OCUK never works out well!
