- 15 Nov 2014
I need a laptop with two hard drives, maybe up to 500gb each. The second one has to be an exact clone of the first one automatically backing itself up quite regularly, maybe once a day.
It is going to be running a couple of cryptocurrency wallets which doesn't take a huge amount of Processing power. Basically that is the entire function of the machine so maybe a core i3-i5 max, but I want the data backup process to be quite fast so maybe an ESATA port may help there So how powerful should the laptop be, should i use SSDs, if so which brands for reliability, what software should I use for the cloning process that isn't a pain in the backside to figure out and use?
Any help would be appreciated. Budget max £650. Remember, it won't be doing anything intensive like gaming etc
