- 7 Sep 2007
Hi Everyone,
I have just joined the forum and you all seem a helpful bunch so I wonder if anyone can help me.
My target is to get 3.4ghz out of my quad 6600 2.4ghz
Now my pc specs are as follows:
975X Platinum PowerUp Edition (Motherboard)
Ballistix pc-6400 (Memory 800mhz) 2gb in dual channel, have orderd another 2gb from overclockers
Quad 6600 (GO SLACR) version processor, with Zallaman cooler
XFX Geforce 8800 Ultra Extreme 768mb Graphics card.
Now at present I have managed to adjust the FSB to 310 making the cpu go from 2.4ghz to 2.8ghz but for some reason cant get it any further as it will either BSOD or simply hang. I have tried raising the voltage but still it does the same. Now I have the following questions:
1. Is this motherboard any good for overclocking??? (or recommend one that will do the job)
2. Can anyone explain the setting i should be changing, I have read various threads but when trying to compare these to my bios them simply don't add up
On the temp side of things I am currently at 44 however i am assuming its because i went a little silly with the thermal compound as i though the mre the better when in fact its the oppposite so depending on step1 I might clean it off and put some more on but less of it and if i need another board could do it the same time, have ordered myself some Arctic Silver5 thermal paste. This should reduce the temp ??
I don't think i am expecting too much am i thinking I could achieve 3.4ghz? tbh I would be happy with anything 3ghz onwards.
I have the cash waiting if i need to get another board so rather than me jumping in and getting anyboard does anyone out there have a similar setup that they can recommend a board and the settings they used to achieve the overclock i desire?
I really appreciate your time in reading this and thankyou all in advance for any advice you can give me
PS. I tried to run that coretemp program and my pc dont like it it just reboots it
Also I dont think this chip allows my bios to give me the option for cpu multiplier?
I eagerly await your help........
