Hello all,
This is my current PC setup -
case: Corsair graphite 230t
Motherboard: asus m5a97 r2.0
Graphics card: zotac gtx 1060 6 core with 2 fans
CPU: AMD FX8350 8 core 4HZ
ram: 2x Hyper X Fury 8gb DDR3 (I have 16GB)
I have little/No knowledge on gaming PC however i have a friend who knows his stuff. He put together this list for me to buy which comes at £450.
https://gyazo.com/af69d4b423b6e7323aae290a13fdebbb
I have a few questions -
When i look up the Motherboard on OCUK, it comes up with 3 which are the same however they have different prices. What are the differences in these motherboards?
1. https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-557-gi.html
2. https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-558-gi.html
3. https://www.overclockers.co.uk/giga...am4-ddr4-micro-atx-motherboard-mb-559-gi.html
Number 3 is the one which my friend recommended however i want to know, is it worth me spending the extra money and buying Number 1 or 2? Will i benefit from spending the extra money?
My next question is about the Ryzen CPU. I searched the CPU on OCUK and it came up with two however they have a different price tag.
1. https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-39z-am.html
2.https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-39y-am.html
I noticed that number 1 comes with a good CPU cooler however it is 3.2GHZ or 3.6GHZ overclocked (I dont think i will overclock my PC) and that number 2 comes without a CPU cooler which means i will have to buy a new one however it comes with 3.6GHZ and 4GHZ overclocked. What will be better for my GTX 1060?
What one would you recommend i get? Will it fit into the PC motherboard which you chose above as i heard the CPU is a different size socket and i want to make sure it fits? Is the 3.6GHZ worth the extra £30 in order for me to get better performance?
My next question is about the RAM. I was recommended to get the Corsair Vengeance Ram which is 8GB and runs at 2400MHZ speed however someone recommeneded i get the RAM listed below as it is garenteed 3200MHZ which is 16GB. They said that Ryzen relies on ram for it to function well? Would this ram work with my motherboard and is it good for the Ryzen CPU?
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
Last question is about the case. My friend recommended the OCUK Benifix nova. However i found this case and i am in love with it!
https://www.overclockers.co.uk/frac...ss-micro-atx-case-glass-window-ca-07e-fd.html
Would this be a better case to go for and will the parts fit inside the case?
And lastly, If i was to upgrade my GPU from the 1060 to a 1080, will these parts be able to support the 1080?
Thank you ever so much for helping me, It is hard finding parts when i dont have much knowledge.
I am willing to spend extra money and make sure that i buy the better performing parts which will last me longer as this is the last upgrade i plan on doing to my PC for a while.
Thanks for any replies! <3
