Sweet thanks man, I will get my friend to read up this forum and make some recommendations for me!
When i click on the Ryzen link on overclockers it says in title its 3.6GHZ but what it doesnt tell you that is the speed it runs when overclocked and i dont think i will be overclocking my PC.
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-39z-am.html
I may be wrong but i am not sure.
- 3,2 GHz Base- & 3.6 GHz Turbo Clock with Precision Boost <-- this is what is stated in the description of the product (Im guessing this means it runs at 3.6GHz if it is overclocked but only 3.2GHz if not overclocked?)
Lets say i am set on the two setups i gave you earlier would you just recommend me to get a bigger board just so it fills the case more?
I plan on sticking a small figure of Rick in the case which will be sitting at the bottom if there is enough space! =P
https://www.amazon.co.uk/Rick-Morty...coding=UTF8&psc=1&refRID=ACM8BMGJ1JYYHNDDK6MT
i dont know then if im honest, not all of the items given details of turbo mode, never owned a ryzen and my i3 was locked, so 3.6ghz was what i had to use, i wouldnt worry too much, they a 6 core 12 thread processor so you got plenty of grunt and if its like an old i5 2 core 4 thread i had in a laptop, it pretty much used its turbo mode most the time,
i wasnt suggesting get an ATX board just to fill the case, but they do tend to offer more features etc over a micro atx and assuming i saw the right case on OC website then you would have plenty of space to stick your funko pop figure in it.
