Need Advice - Graphics cards and Overlays....
28 Sep 2004
Hi, I know a little bit about overlays and there restrictions, and most applications annoying tendancy to only maximise to primary monitor.
Is it possible to have 2 overlays running if using 2 seperate cards?
What I would like to do is have a single card running my 2 monitors, then another card for running my TV. This should mean I can run overlays on both the TV and one monitor at the same time (I assume)
Also, what are the best cards for component output?
Cheers
