Need advice on a gaming pc
28 Jan 2013
So after using a dell Xps 17 so over a year now, I've decided i never use my laptop for its mobility so im going to get a desktop.
From looking around on here a lot this is what ive come up with so far.
I would Just like advice for if i should get anything better or if it wouldn't work etc.
Im tempted to go for the 7950 gpu as i will use this for gaming at 1980x1080. Price is quite stretchable but sticking around 700 would be nice unless something is defiantly needed.
1 x Z77 Gamer Intel Core i5 3570K 3.40GHz @ 4.50GHz DDR3 Ivybridge Overclocked Bundle
1 x Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card
1 x Cooler Master GX Lite 600W '80 Plus' Power Supply
1 x BitFenix Merc Beta Gaming Case - Black
also with standard things like Disc drive and Hard drive totals in at £675 including wifi card etc.
the view cart doesn't work for anyone but you, better to list what you are looking at etc
or give a budget of what you want to spend etc and we can quote you happy :)
lol! you're right! it actually is =o
7950 is about 20-25% faster than the 7850. depends on how long you wanna keep the rig i suppose
Ok so i can just put the bundle in to your choices and that would work?
and im very tempted because 25% is quite a lot faster.
Also whats the difference with the GPU being *B* grade ?
yes
YOUR BASKET
1 x Z77 Gamer Intel Core i5 3570K 3.40GHz @ 4.50GHz DDR3 Ivybridge Overclocked Bundle £315.98
1 x **B Grade** Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showd (GX-100-GI) £129.95
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £82.99
1 x Corsair Builder Series CX 430w Modular '80 Plus Bronze' Power Supply (CP-9020058-UK) £38.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £33.5
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
1 x Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter £16.79
Total : £685.18 (includes shipping : £12.50).
http://www.anandtech.com/bench/Product/549?vs=550
an even better deal is the b-grade 7970 ghz edition on for 250 quid atm, which is just 20 quid more than the new 7950. (but with a corresponding psu upgrade too)
YOUR BASKET
1 x **B Grade** Gigabyte ATI Radeon HD 7970 GHz Edition Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfigh (GX-108-GI) £259.99
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £49.99
Total : £826.22 (includes shipping : £12.50).
b-grade means its a return/damaged box/missing some accessories.
but because the gpu is a gigabyte, they deal with serial numbers on warranties, so the fact its a b-grade doesnt mean jack, warranty-wise
aka good deal
aka good deal
ok well from those numbers i cant really resist the upgrade :)
last question then, since ill be getting the 7950 and with the cpu being overclocked willl heat be an issue ? do i need to get a better cooling system or anything or will the system you recommended suffice ?
thanks again for answering all my questions.
if you're gonna get the 7950 new for 240, i'd rather suggest the 7970 ghz edition of 260 quid tbh.
and no, the megahalems would do just fine
just fyi, i didnt make it clear in the last post, i meant the 260 quid b-grade 7970 ghz edition (still gigabyte, so warranty shouldnt be a problem)
and yea, once you go ssd, you'll never go back. ever.
ye i found that one :) right well the system seems all good, thanks for you help.
now to buy and build it :D
