Im building myself a new rig soon and have got most of it sorted now thanks to two very helpful people
. One of the things left to do is pick a case, and thought this should go in the case section instead of my post in general.
Im looking for a black case with plenty of room. The Coolermaster Stacker STC-t01 really caught my eye, but sadly there are no black ones to be found
. The second case that has caught my eye has been the silverstone tj05. Its within my £100 limit i have set for the case, is black and has a nice layout and a right set of fans in it. The only problem is i think the position of the usb, firewire ports on the right hand side of the case is a bit awkard and i seen that the LCD panel can be awkard aswell if you dont look at it from the right angle.
I was hoping some people could give opinions on the Tj05, and maybe suggest a few other cases fitting the description. I am not too keen on the design on the Lain li atm so i dont know if i could go with one of them. All help is well appreciated
~cheers
. One of the things left to do is pick a case, and thought this should go in the case section instead of my post in general.Im looking for a black case with plenty of room. The Coolermaster Stacker STC-t01 really caught my eye, but sadly there are no black ones to be found
. The second case that has caught my eye has been the silverstone tj05. Its within my £100 limit i have set for the case, is black and has a nice layout and a right set of fans in it. The only problem is i think the position of the usb, firewire ports on the right hand side of the case is a bit awkard and i seen that the LCD panel can be awkard aswell if you dont look at it from the right angle.I was hoping some people could give opinions on the Tj05, and maybe suggest a few other cases fitting the description. I am not too keen on the design on the Lain li atm so i dont know if i could go with one of them. All help is well appreciated
~cheers
