hi all i need a little advice i am wanting to upgrade a few things in my pc but not sure what to upgrade or even what is good these days
my pc specs
i7 930 @2.8GHz
Asus sabertooth x58 motherboard
6 GIG XMS3 ddr3 1600MHz triple channel ram
cheap £30 650 watt PSU
CM Scout case
250Gb hard drive
2Tb storage drive
EVGA 550Ti OC graphix card
Cooler Master Seidon 120M Watercooling System
things im thinking of getting
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
Akasa Venom 750w Modular '80 Plus' Power Supply
OCZ Vertex 2E Bigfoot 180GB SSD
Akasa Venom Toxic Full Tower Gaming Case - Black
i have a budget of around £300 to spend i know my GPU isnt that good but it will have to do till i can save and get a better one and it
does the job for now im just not sure if i should just upgrade the parts i have put above or keep saving for a new build.
any advice would be great thank you in advance for your replys
my pc specs
i7 930 @2.8GHz
CM Scout case
250Gb hard drive
2Tb storage drive
