- 19 Aug 2011
- Leicester, UK
Hello,
As the title suggests I require some assistance regarding air flow. I currently have an Antec 300 case with the following set up:
Rear - 12cm fan intake(connector to Corsair H50 CPU cooler Radiator) ??? CFM
Top - 12cm exhaust Antec Tricool fan at medium setting 66.8 CFM
Front - 2 x 12cm Akasa Venom running at full rpm(have no fan controller) 83.6 each (166 total) CFM
How ever I wanted a bigger case so I ordered the HAF 912plus, which should arrive on tuesday 7th Feb. Was wondering if I should keep the defaults fans in that case or should I use my Venom fans. The default 912plus setup would be:
Rear - 12cm fan intake(connected to Corsair H50 CPU cooler Radiator) 44 CFM
Top - 20cm exhaust 110 CFM
Front - 20cm intake 110 CFM
I ask this, because I was thinking of either swapping out the front fan with my 2 venom fans, but was unsure if taking in more air in than can be pushed out is bad, or putting 1 venom intake at the rear and using the other on the side.
The whole air flow this is confusing me a little.
I would appreciate all advice.
Thanks Shadow-King
I would appreciate all advice. Thanks Shadow-King
