Ok, I've just got myself a new AMD x4 955 and I'm having some temperature issues that I've never had before with previous cpus. I'm already trying to understand/solve the cpu heat issue in the Hot & Loud thread.
Here I'd like to address the issue that when I put the cover back on the cpu temp increases by up to +17c despite having installed a fan at the front to suck air in and a fan at the back to blow it out (admittedly the akasa fan at the rear is doing a very poor job, but the faster spinning akasa fan at the front blows strong). I've gone with 80mm fan due to size limitations in my case, although I might be able to install a 92mm at the rear if that makes a difference...
Below is a picture of my case. I'm thinking of getting a more powerful fan to blow the air out the back of the case, but other than that can't really think of much else. I'm not about to change case, but any other suggestions are very welcome.
