Need Excel Help...
14 Oct 2007
Morning All,
Basically, I have a spreadsheet with several columns, 2 of the columns are 'Date / Time Raised' and 'Priority Level'
For example:
Date / Time Raised: 17/07/2013 08:00:00
Priority: 3
Now, if Priority 3 is 72 hour fix, can the row highlight red when it reaches that time period (20/07/2013 08:00:00) then if it is still on the spreadsheet by this time, the row will highlight red alerting me it is over the priority time scale?
Hope that make sense...
If your dates are in Column A, for example, you can use this formula to get the amount of hours that have passed between now and the date:
=(DAY(NOW()-A1)*24)+HOUR(NOW()-A1)
...then, with conditional formatting, you could build up some rules using the formula; something along the lines of:
Condition1 = Formula is =(DAY(NOW()-A1)*24)+HOUR(NOW()-A1)>72 ......(72 is amount of hours)
Thing is, certainly with earlier versions of Excel, you can only put 3 conditions in place; this means you can get a 4th only be making it the default/normal position.
Hope that is a start point :)
Perfect mate thank you :)
