Need to build or buy a PC have built a few in the past but was a while ago
this is one of the games i'm looking
at playing and the min spec
http://na.finalfantasyxiv.com/#/about/game_info
windows xp sp3
windows vista/7 32/64
intel core 2 duo 2 ghz
amd athelon xp 2 ghz
2 gb memory
geforce 9600 with 512 vram
ati radoen hd 2900 512 vram
1280 x 720
direct x 9.0c
budget for this build is 1k 1.5 max thinking that would be over the top
not looking to max out the budget but would like to max out bang for buck
be nice to have a pc to last a few years at least
i would go for stability over performance with scope to upgrade in the future
also need something thats wont sound like a helicoptor sitting in the room with me
just need this to play games on as i
have a few other PCs about for everything else
also anyone have any info on using a HDTV
instead of a monitor
looking to get this either ordered and
on way by tues or i can collect from shop tues/wens
any help would be awsome
looking at the ready built boxes on webiste as well so one of those may be a better idea for me
windows xp sp3
2 gb memory
1280 x 720
direct x 9.0c
