Need for speed shift performance.
20 Nov 2006
My performance in this game isn't as expected.
Running 1920x1080 with everything else maxed, I am getting about 32-40 FPS on a populated track.
Id expect more from crossfire 5870's, 4GB and a 965 BE.
Am I doing something wrong here or is this game really THAT demanding.
You should be much higher than that. I had it running at 1680x1050 / 4xssAA at 40-60fps with crossfired 5770's, with all settings on max.
You sure crossfire is enabled ?
Only other thing I can think of is update Physx, as Shift uses it for collisions, etc... afaik.
Make sure the game is fully updated as there was major performance increase for ATI cards in a patch, the game likes a quad CPU at a decent speed.
Patched to latest version?
I recall there was some major problems with ATI cards when the game first came out.
I'm playing it on a 5870, v-synced and get a constant 60fps at 1920x1080, 8xaa
