Need hard drive advice please
22 Jan 2007
Hi, I'm deliberating over whether to get a 1Tb sammy or 2 500Gb drives. I'm going to install the windows 7 beta on the drive/ 1 of the 2 drives. Problem being there seems to be only seagate 500gb drives floating about which i've heard 2 many problems about to put me off them and the rest dont seem to have the performance or are too dear.
My intentions are too use if i got the 1gb sammy for both os and storage or too use 1 drive for storage/backup and the other for os/programs.
Budget is £90-£100
Would appreciate suggestions or alterative lines of thinking thanks.
P.s I dont necessarily need 1Tb if performance/storage need to be compromised.
Personally I'd go for the 1TB Samsung drive and partition it keeping all valuable data on a separate partition, then if funds allow buy an external for backup so that the data is kept on 2 separate drives...
