Ok so after a lot of hmmming and rrrring I bit the bullet and picked up a new (well new looking) laptop from dells outlet a Alienware 13 with a 1060. Initial impressions were very positive very nice bit of kit.
I know theirs been temp issues with Alienwares so first thing I did was run Alienwares own stress test and then I installed and ran XTU.
I did a quick 5 min stress test on XTU and the benchmark which also takes about 5 mins
CPU max temp was 99c
GPU on the Alienware test was high 80s
Now I not had a gaming PC for a while but those temps look very high !! to me
I ran the above with standard fan profile
I decided to run it again with the fans on max, (i'e full blast regardless of what your doing) and temps were around 80 both CPU and GPU
I'm not keen on the fan full blast mode as its noisy, and overkill when not gaming and will likely wear out the fans
I'm not an expert but I seen people getting better temps than this (70s), I'm not keen on repasting a new computer so was wondering how do people do these tests, as if they do them full fan blast mode then I'm around 10c worse so maybe not to bad, but if people are getting that on the standard fan profiles then I,m 30c worse which is very bad
I don't fancy it's going to have a long life if it's running in the high 90s everytime I play game
What's people's thoughts on this ?
