Need help/advice
28 Dec 2010
My Specs are:-- Intel i7 930 2.8Ghz
- 6GB Ram
- Asus P6TD deluxe
- Ati 5970
- Windows 7 64bit
- Titan Fenrir Cooler
- Corsair HX 750W ATX Modular SLI Compliant Power Supply
Been trying to overclock this for ages now and im getting a problem which i cant seem to sort or find any information about it anywhere online and ive searched for about 20+ hours already! Well basically what happens is i do my overclock and run 20 runs of linxs to check stability and it passed, i also ran prim95 for 2.5 hours and it was all good on this to. Heres the problem... When i turn off the pc and go back on it in say 8 hours time it gets to the starting windows screen and never seems to load past there. What i need to do is hold the power button to turn it off and then remove the power cord for a minute or so then plug it back it and when i load it up again it boots up fine :S
OVerclock Settings Ai Overclock Tuner.....................[Manual] CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
BCLK Frequency.........................[181]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1451MHz]
UCLK Frequency.........................[2903MHz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.23125
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.22500]
IOH Voltage............................[1.14 IOH
PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto
DRAM CTRL REF Voltage on CHA...........[Auto
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto
DRAM CTRL REF Voltage on CHC...........[Auto
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto
PCIE Spread Spectrum...................[Disabled
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
ive tried the settings all different ways and ive tried voltages up to 1.35. these settings are near enough what i have now but ive tried changing them around to get it to work. Since im not at home i cant give you the exact ones at the moment...
