- 14 Jun 2004
- Den Haag, Netherlands
So I'm almost at the point that I'm buying hardware to refresh my ancient Home Server.
I'm seeing a lot of good things about Ryzen 3 at the moment, but I'm pretty confused as to what to go for.
My use case/requirements:
- I'm looking at UnRaid as base OS
- Virtualisation within Unraid (Couple VMs and Docker, homelab stuff)
- NAS SMB/NFS storage
- Plex (Plex mainly 1080p transcoding, but looking to go to 4K in future)
- Lots of fast SATA storage ports (ideally 8 onboard)
I've got quite a bit of the basic hardware I can use from my existing server:
- PSU (Need to check, but I think its 700W)
- Case (large enough for 8 drives)
- Disks (Have enough disks)
Two of the main questions I have around this setup is CPU and Motherboard.
On the CPU side, should I go for an APU like 3400G and not need a graphics card or go for something more like a 3600 or 3800?
On the motherboard side, should I go for something in the X570 range or is something in the B450 range more than good enough? I've always in the past overspent on motherboards.
I'm also trying to manage the cost, if possible, so I think I need:
- CPU
- Motherboard
- Memory
I'm looking to maybe keep costs within 400 for these items.
I've been up and down the forums for a while, hopefully this will be enough to help a recommendation.
- CPU
- Motherboard
- Memory
