When you double click it does it then ask for a destination to extract to?
Ah yeah just wanted to make sure incase i didnt ruin my computer
The PC boots up fine it passes the BIOS but fails to load windows which displays the IRQL_NOT_EQUAL_OR_LESS error with the graphics card and without.
Okay i will do that, Only displays half of the screen when the AMD card is in.
went into half screen...ARGH!!
Im running out of ideas,
• The monitor cable is secured tightly?
• Try another output on the GFX card such as the HDMI if you can.
• Try the card in another PC such as a friends?
• RMA it.
