need help building a new pc
3 Aug 2009
hi its my first post so tell if its in the wrong section.
anyway i haven't built a computer since 2003-2004 and i havent kept up to date with the computer world since then but now im looking to get a new pc but i dont know where to start and i coulld really use some help.
im looking for a gaming pc even though im gonna use it with a lot of sound applications for work but i have some external hardware so the soundcard doesn't have to be "great" the processor speed does.
i was looking at an i7 seeing as its chipset would last me for a couple years
upgrade wise, with that in mind the motherboard and case also has to room (options) for upgrades as i may want to add mulitple graphic cards and pci cards down the line.
i want to try and keep the price under £1000 actually more like a £500-£900. i dont know if im missing anything spec wise or if theres been major changes since 2003 but any help with choosing the parts would be completely awesome.
thanks
Is this just for the base tower unit? or to include things like monitor? OS? kb/mouse? speakers?
Edit: If it were just the tower, this would be ideal, but it is over budget and doesnt include a dedicated sound card either, depending on your needs re sound depends on what card would be best, but something from the asus xonar range would be good, you can easily bring under budget by lowering case and possibly cooler too, but I included these as if youre wanting high end sound production you dont want to hear your components
thanks a lot i tried to combine the 2
is it all good?
i got a lot questions about it if someone doesn't mind helping.
i dont know if these parts are better
Asus Rampage II Gene
powercolo(u)r ATI Radeon HD 4890 1gb (is there a big difference)
BFG GeForce GTX 275 OC 896MB [is it better than the 4870 (is there a difference from the ati cards)
Corsair TX 650W ATX SLi (does sli mean its for sli cards? and is it any better than the one i chose?)
is the fan good?
and is there a cheaper case under £100 with good cooling, space and easy upgradeability as i dont really like lights in a pc.
i herd that you can use the ati crossfire with any ati hd cards, so can i get a 4890 and crossfire it with a 4870 no matter the brand and is there room on the motherboard to do that?
i know its a lot of questions, lol. honestly i dont know and it seems like in the last 6 years theres been more acronyms created than ever.
but really thank you guys for the help.
dont bother with the rampage gene, its only mATX, if youre wanting to do it on a budget drop the mobo back again, either the P6T SE or the gigabytes UD3R, Id use that money to spring for the 4890, also Id get better RAM, that may hold back your OCing potential, either 12800 (£80) or 14400 (£90)
Thats one of the best performing cases in its price range, but if you really dont like lights start a thread in the case section where you can get more detailed advice on which of the Lian Li's to look at, theres so many of them, lol, the coolermaster range is pretty good too but again they tend to use LEDs
If a PSU states SLI or xfire compatible its just that its been certified by NVidia or ATI respectively, they can still be used on either set up, the Corsair is a better PSU than the OCZ
Yeah its all compatible
so out of the p6t,p5tse and ud3r what is better? cus i was just gonna go with the p6t as i herd people having probs with the ud3r.
afaik the only difference between the base P6T and the SE version is the SE doesnt support SLI, as youre going for an ATI card you may as well save yourself the cash
