Hey guys, i really dont know much about hardware terminology etc and I want to buy a new HDD for my PC. (since ive decided not to buy a new case)
Neways, my pc HDD has this spec:
Capacity: 80 GB
Speed: 5400 rpm
Cache: 8 MB
Brand Seagate
Type: ST980811AS
Family Momentus: 5400.3
Form Factor: 2.5"
Interface: S-ATA
here is a link to it
http://support.packardbell.com/uk/item/index.php?i=spec_hdd_7415310100&ppn=PB81X06201
Ive looked at the HDD on the website but most are SATA II and the ones that are not has speeds like 3gb/s which i think will not work on my pc
So is it ok if i pick up any Sata HDD? or would i need a specific one?
If its possible can you recomend a 1TB - 2TB HDD please?
Thank you very much
Capacity: 80 GB
Speed: 5400 rpm
Cache: 8 MB
Brand Seagate
Type: ST980811AS
Form Factor: 2.5"
Interface: S-ATA
Thank you very much
