need help choosing a graphics card
2 Mar 2007
Hi guys and Gals.
Looking for a good graphics card.
My budget is £180
I will be using it mostly to do 3D modeling, Animating and rendering and a lot of photoshop work.
Would be nice to watch 1080p movies.
What GPU do you guys recommened.
Current system Specs:
CPU: AMD 64 FX-62
PSU: thermaltake 750w
MB: ASUS M3A32-MVP
Memory: Corsair 4GB DDR2 PC2-8500C5
GPU: Nvidia 7800GT
My computer Crashes when im doing too much 3D work hopefully a new graphics card should fix the problem and make everything faster
Edit: would these do the trick http://www.overclockers.co.uk/showproduct.php?prodid=GX-074-BG
for that budget you could get a 4870
but...
the rest of your system may bottleneck it
what speed is your processor?
i suggest maybe an 8800GT minimum
but the 4850 is the safe bet
