Need help choosing case!
I think the 330R is definitely prettier, if it had those rubber gromits it would be perfect. It just looks like it's more of a premium case, and I think that's because of the finish.
The ghost just looks a little too plastic and that's what'd put me off.
Ace does the P100 have duel fans at the front it looks like it in the picture but says single in the spec. Also does it have air filter on the top mount?
The top doesnt have an air filter but you should not need an air filter on any fan vents which pushes air out the case, you should only need vents for intake fans.
The front comes with a single 120mm fan, but has an extra mount for you to fit an option second fan.
