- 3 Jan 2019
The Corsair Glaive RGB is designed for gamers with larger hands, has a 16k DPI optical sensor, onboard profile storage, RGB lighting, and adjustable thumb grips!
https://www.overclockers.co.uk/cors...led-16000-dpi-optical-aluminum-kb-09h-cs.html
), quite like it, my only criticism is with the scroll wheel... Even with the tension set, a quick flick will result in a short "free-wheel" which I don't like. Other then that, comfortable when in use and more buttons than you can use
