Need help Desktop problem!
9 May 2009
Kent
guys i got a problem that is driving me insane. Just trying to play bf3 all is going well, i tab out and somehow have activated some command and everytime i hit any key on my keyboard it opens random programes from my desktop. How do i turn it off :S
Help!!!:confused:
Ive clicked some combination of ctrl blah blah or something on the keyboard some how and now all my keys on the keyboard are shortcutting the programes on my desktop. Ive done this before a few months ago but cant remember the command to turn what ever ive turned on.
No one????? Im having to use a laptop just to type this msg as i cant type anything on my pc with each damn key opening up random **** on the verge of smashing it up.
I had this same thing last night in game with a voice telling me what programmes it was scrolling through
For me it was definately sticky keys as I was holding down the shift keys, I turned off all sticky key applications and it went away.
I dont know how to access the sticky key application but if you hold down right shift for more than 8 seconds while in game you should hear a beep, alt tab out and you should get a diag box, just disable all the applications and you should be good to go
