need help fast please
21 May 2007
on your roof
when i load up the bios on the first boot it checks through then says
PXE-E61 please check meadia cable and insert system disc.
well i would like to know how to fix this problem and also *** the system disc is. please help thanks. :confused:
The PXE message indicates that the system is trying to boot off of the network using the PXE protocol. This would indicate that normally that it hasn't been able, or tried, to boot off disk or optical drive, i.e. the machine cannot find an OS, or "system", to boot.
Check that your bios that your boot device order is correct and that the system is seeing the disk and optical drive devices properly from the bios.
