Need help finding a Wifi driver
What do you mean the shield is half off?
When you remove the cover on the underside of the laptop and look at the WLAN card there is a silver foil/sponge backed type item which I assume is a sort of heatshield which looks to have been stuck down fully at some point in time but has now came away slightly from where it is attached. Upshot is it can now be gently moved aside to access the details on the WLAN card itself.
