If you have a XP disk , this contains the necessary files to either repair a bad XP installation or start a fresh . As you boot up , enter the BIOS and make sure you you first boot from a CD drive [it may be IDE0 now]. Put the XP disk into the drive and watch the screen carefully , as it recognises the CD disk it will only give you a few seconds to press any key to load .
Follow the instructions , you can repair or re-install .You re-install by formatting the drive in NTFS .Everything is straight forward from then on. This will not work if you have a brand new drive ....this has to be partitioned using fdisk on a Windows 98 disk .
Again dead easy . Download a boot disk from the Bootdisk.c-o-m. Change the BIOS to boot from floppy . Insert floppy and boot up. You have the option to load with CD drivers or without .Does'nt matter , but I always use without .The floppy will load the needed files and give you a A:\ prompt . Type fdisk , type 1 , then 1 again and wait for it do the business .It will want you to re-boot , So ,press Ctrl -Alt & Del and it will re-boot .
Load without CD drivers again , and it will give you the same A:\ prompt . This time type in format C: , you will get some text wanting you to type a 'y' do so and wait .An 80 gig drive may only show up as a 10 gig , dont worry , after formatting it will show up correctly .
Remember , the drive will be formatted as FAT32 but it will be ready for your XP disk as long as you format from the XP disk in NTFS.If you want to load XP , change the BIOS to boot from CD drive. If you just want to use this drive as a backup, link it to your PC through the secondary IDE lead as master or slave.Once recognised in windows , right click the drive - format as NTFS. However you can still load windows onto a FAT32 drive, but ,there are advantages in doing it in NTFS.
