- 30 Oct 2002
- Inverness (UK)
It will work. Done it numerous times.rickyt said:This will not work if you have a brand new drive ....this has to be partitioned using fdisk on a Windows 98 disk .
rickyt said:Change the BIOS to boot from floppy . Insert floppy and boot up.
He doesn't have a floppy. (3rd post)
As Gavstar said though - If you can see your E:, you should be able to see your C:...
Remove all other HDD's from the system... Just have the OS drive in, then see what happens.
