need help - k750i updating
11 Jun 2004
hi i want to update the firmware/software on my k750i but i dont have the usb cable... can i not send the files via bluetooth or put the update on the memory stick and do it that way?
is there anyway to update the phone with usb cables??
thanks
thanks
i found my usb cable just need the software etc. can anyone help? also do you loose your address book when upddating?
thanks
if it works the same way as my w800, you need the seus software from sony ericsson.
SEUS= sony ericsson update software, and gets all the official updates etc. Just make sure you follow the instructions and it works a treat
ps. didn't lose anything from my phone, but if you have the software for it I would do a back up, just in case
do it through the sony ericsson website... it downloads a little flash application -> follow the steps.
i didnt lose any messages, phone numbers or photos/movies/games etc.
