Need Help on My System Specification
1 Dec 2025
DC
Hi,
I’m looking for feedback on the expected idle temperatures for my Ryzen 5 7600X and any advice on making sure my RAM is configured optimally.
Currently, the CPU idle temperature is around 45–50°C, and my memory latency is about 71 ns. ( Expo enabled)
Could you please share any suggestions or recommendations to improve these areas?
*RYZEN 57600X
*DDR5 CORSAIR DOMINATOR 6000MHZ CL30 16GB X 2 - AMD EXPO
*GAMEDIAS CHIONE E4 - 360 AIO
*ASUS TUF GAMING B850 PLUS WIFI
*ASUS TUF GAMING RTX 5060 TI 16GB OC
*CORSAIR RM750e 80+ GOLD
What's the load temp in games (assuming you're a gamer)? If the load temps are fine then that's not a concern, assuming your fans are quiet and the pump isn't running flat out.
I just completed the build, and I haven’t played any games yet — I’m still fine-tuning the system. Prime95 pushes the CPU temperature up to 95°C within seconds, while Cinebench R23 and AIDA64 keep it around 83–85°C during a 30-minute test.
The chassis fans are running at full RPM all the time, and the pump is operating at 4500 RPM, which is a bit loud. Curve Optimizer is currently set to negative 30.
The Cinebench/AIDA temps are alright, but the pump and fan RPM sounds wrong, especially if you're minus 30!
That said, I've never heard of the AIO you're using, so I don't know how it is supposed to be running.
im not sure what you mean by. Could you brief what i should do? The AIO settings were default
The part of the AIO that screws down onto the CPU and has the thermal paste on it, normally comes with a thick protective plastic film on, it's a common mistake that people make and forget to remove it, this will create an over heating CPU.
