Need help on ordering a cable?
4 Aug 2012
So, I'm building a PC for a friend and coming to plug his gpu (Asus 760 DirectCU II) into his power supply. But the only cable that came with it is a dodgy 8 pin (into the gpu) to two 6 pin adapters that don't connect to his power supply. I think I have found the problem is that he is missing a cable that comes from the power supply and plugs into the 6 pin that comes off the GPU. His powersupply is a Corsair CMPSU 650HX Professional series but I don't know the name of the cable he needs to order to connect his power supply to his GPU. Thanks
- Nathan
Is that a molex to 6/8 pin converter?
If so, get a new Psu if his existing one doesn't have the correct connections actually coming from it.. If you use an existing molex connector, then I doubt the psu will be of a decent standard!
You should already have the cables available on the psu, you only need to use that adaptor if the psu does not have the necessary cables. I think you maybe mistakingly be trying to use both the gpu adaptor cable and the psu cables.
