Need Help On Upgrade Please :)
Hello and welcome to the forum :)
Could you give the model of your CPU so we can confirm this will work with the motherboard specced.
if your thinking of going ssd then stick with the original mobo has it has the sata 6Gb/s ports.
what gfx card are you running on the system , long as you don't have or plan to add a high end card then the psu will be fine.
