Need help overclocking...
18 Dec 2010
I have the following spec:
Asus P8Z77-V
i7 3770K
Crucial 8GB 1866Mhz CL9
I read on an article the following:
- If optional, increase/release the TDP limit of your processor to 200~250 Watts
- And now set the TURBO multiplier at a maximum of your liking, we applied an MP of 48 on all four cores
- Increase CPU voltage, though setting AUTO might work fine, we applied 1.425V (which is reall high)
- Make sure your processor is properly cooled (we used a Noctua D12 heatpipe cooler and forced the fan to 60% RPM)
- Save and Exit BIOS / UEFI
Now my question is:
1. Where do i locate the TDP limit on my mobo? i can't find it.
2. Profile is set to XMP atm or do i change to something else?
3. What voltage do i set? or leave on auto? also any other voltages to set? i have a feeling auto sets the voltage quite high which will effect temps
Thanks
