Need help sellecting a Bundle
26 Feb 2009
Hi all Im trying to sellect a cheapish bundle and I have found two to pick from but not sure need some advice ! ( I was looking spending around £400-500 but Ive had to change that estimate :( Unfortunately to around £200)
1, AMD QUAD CORE Phenom X4 9500 Hybrid SLi Motherboard Bundle and 2GB DDR2 Mem £189.99 (Listed on another site lol )
2,*OVERCLOCKED* Intel Pentium Dual-Core E5200 @ 3.20GHz / Gigabyte GA-EP43-DS3 Intel P43 Motherboard / Kingston HyperX 4GB 8500C5 DDR2 Bundle £194.99 http://www.overclockers.co.uk/showproduct.php?prodid=BU-029-OE
So which one?
atm Im running amd 4800+x2 with 2gb of mem
or
£194.99
Could you link me to these, it takes a while to find them. Will make my life easier :P
thanks for the reply guys, I thought the quad core would have been better than the dual ( thank god for forums :D)
now linked.
now linked.
The Quad is better than the dual, although you could probably get the same stuff on Overclockers for less.
Go for the E5200; it might only have two cores but it will be a lot quicker than the Phenom, and it comes with 4GB instead of 2GB of RAM.
