Need help speccing cheap LAN PC
31 Aug 2013
So my wife and I are wanting to play Empire Earth 2 via a LAN connection.
Could anyone help spec me up a PC that would run this no problem? I'll be installing Windows XP and it'll remain offline.
There's no 'budget' for say, just cheap and cheerful will do.
It's just for some fun! :)
Any help is much appreciated :)
You can find pre-built PCs being sold 2nd hand that go for ~£100 that will do that for you, just look around. Otherwise making something new will cost around ~£200.
Minimum system requirements - Windows: XP / Vista / 7, 2.2 GHz Intel Pentium 4 or AMD Athlon or faster processor, 512 MB RAM, NVIDIA GeForce 4 or DirectX 9.0c-compliant 128 MB 3D video card with hardware T&L and pixel shader support, minimum screen resolution of 800x600, DirectX 9.0c-compatible sound card, Mouse, Keyboard.
That's awesome! Thanks mate!!
I was so silly looking all today at Intel and Nvidia. Totally forgot about AMD.
I take it AMD is just as reliable just aimed at a lower end of the market?
Is the processor overclockable?
Thanks again man! Saved me nearly a £100!! :)
Second option seems a bit more like it, would like to run other programs on it as well.
Can't believe you can get a 120gb SSD for 39.99!! I remember when they were like £250 and that was only a few years ago!
