Need help spec'ing DAW build for a friend. (£540 budget)
9 Sep 2013
A friend of mine recently had their house broken into and the insurance is playing silly buggers. He is a musician and used to use his old laptop for recording, wasn't great, but done the job. Since they stole that he's at a bit of a loose end. He asked if I could spec him up a rig that would allow him to use programs such as Cakewalk Sonar X2, Reason 7, Ableton live 8/9 but also something he could possibly enjoy some game time on.
This is what I have come up with so far. But I am sure there are some here who could help greatly....so here we go.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-337-AM
http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS
http://www.overclockers.co.uk/showproduct.php?prodid=GX-183-MS
http://www.overclockers.co.uk/showproduct.php?prodid=MB-214-MS
http://www.overclockers.co.uk/showproduct.php?prodid=HD-392-WD x2
http://www.overclockers.co.uk/showproduct.php?prodid=CA-116-CS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-076-AE
http://www.overclockers.co.uk/showproduct.php?prodid=CD-090-LG
Total via OCUK comes to £533.36
I have listed 2 WD Caviar black drives there as he requires one for his OS and another for all his samples/audiofiles.
Obviously there is no OS here, which is something which will need to be sorted.
Sorry don't know how to pop it all in as a cart thing like most do on here so just posted the links >.<
Any help would be greatly appreciated.
Cheers, looks good but really need to keep this around the £550 mark as will need to factor in operating system also. I was originally thinking on SSD, but at the price it's a bit too much.
AMD Piledriver FX-... 1
MSI HD 7750 2048MB... 1
Seasonic S12II 520... 1
Western Digital Ca... 1
Gigabyte 970A-DS3P... 1
Toshiba (7K1000.D)... 1
TeamGroup Elite Bl... 1
Xigmatek Asgard II... 1
OcUK 24x DVD±RW SA... 1
Subtotal £499.86
£416.55 ex VAT
£514.86 inc vat & delivery.
How about this?
Would honestly prefer to build him an intel system but don't think I can get away with that with his budget.
Scratch the above spec I made.
He's said he can stump £620 max
The above spec by ExRayTed is tickling his fancy at the moment. Any advances on that whilst keeping under the £620 budget?
YOUR BASKET
1 x Intel Core i5-4570 3.20GHz (Haswell) Socket LGA1150 Processor - Retail £161.99
1 x MSI HD 7790 OC 2048MB GDDR5 PCI-Express Graphics Card with FREE GAMES £109.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £84.95
1 x MSI B85-G43 Intel B85 (Socket 1150) DDR3 ATX Motherboard £68.99
1 x Seasonic S12II 520W '80 Plus Bronze' Power Supply £59.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £47.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £47.99
1 x BitFenix Merc Beta Gaming Case - Black £32.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £645.96 (includes shipping : £11.75).
Right, here we are so far.... Would love to try trim this back to £620ish, but don't want to cripple the system. Any idea's ppl?
Would it be worth phoning OCUK to see if they can offer some sort of bundle price/deal?
YOUR BASKET
1 x AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail £149.99
1 x Gigabyte 970A-UD3 AMD 970A (Socket AM3+) DDR3 Motherboard £79.99
2 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £53.99 (£107.98)
1 x Xigmatek Asgard III Gaming Case - Black £27.95
Total : £615.86 (includes shipping : £12.50).
Substituted the ssd for another seagate, he can always upgrade later.
Spoke to his wife today, she is looking to get a PC ordered for him tomorrow. So any help or advance on this would be very welcome.
I really want to make sure this system is stable for him and although as you can see, there is no OS. I think he will go with the option of a trial version of window's 8 and then purchase, or possibly window's 7 if I can find a cheap enough oem for him.
His max outlay is £630 and as said, the system above is NOT set in stone yet so any help would be greatly appreciated.
As this is for a pc which will be used for recording/multitracking music the seperate drive is needed for his sample libraries/program libraries and project folders. Unfortunately putting it all on one HD won't work as it will slow down and reduce the efficiency of the Software he is using.
